ABS out of calibration ?
But what is the diameter of each of your original (stock) tires? If, for example, the stock front tire is taller than the stock rear tire, in that configuration the front tire would be rotating more slowly than the rear tire would be. Then, when you changed both tires so they were rotating at the same speed, this would throw the ABS calibration off.
i'm not sure that this is the case. we switched wheels/tires from the stock 18/16 on my wife's bike to the cvo sized 19/18 and the bike threw no codes. as long as you are using the stock Harley sized tires, the 16, 17, 18 and 19 inch front tires are all virtually the same overall diameter. for the rear, the stock 180/65-16 tire has an overall diameter of 25.2'', while the new 180/55-18 has an overall diameter of 25.8'', increasing the circumference of the tire by 1.8'', and the diameter by .6'' (raising your rear .3''). i'm not convinced that that is enough of a difference to cause the ecm to throw a code, especially given that hd uses those same sizes.
ABS Calibration
Ok, solved the ABS problem for those following. I purchased the rear wheel off of Ebay which was a "new" never used display wheel with the bearings installed, the correct ABS bearing was installed as per the part #'s. The problem turned out to be that the ABS bearing was installed with the part numbers to the outside as you can read them which is what I would have thought to be the correct install, turns out the numbers are installed inward as the correct way which is reflected in the code read, as for the tach code it disappeared with the rear sensor code ! All is well, no ABS light on and no codes all because of a incorrectly installed rear ABS bearing ! Hope this helps someone else also. Thanks for the help and remarks !
kap1 (06-27-2017)
Ace07FXDL
Wheels/Tires
01-10-2013 08:31 AM
appling streetglide
Touring Parts
07-20-2012 07:09 PM
