Dealer Dyno tune, worth it?
#31
#32
I'm no expert but have used PV on 2 bikes. Assume your using "Basic" with factory O2 sensors? When you go to Autotune set-up, timing is changed for the process making the bike run crappy. And you really have no need to be running in the open loop area, like 80+mph! Just fill in your graph the best you can, look for % change, export learned and load new map. Now go party!!!! When % change is in the +- range of <5%, you're about done. Hope you bought from Fuelmoto for support
#33
Received 19,509 Likes
#34
#35
#36
#37
#38
