Tire pressure?
Old 06-16-2017, 10:31 PM
5150northrider's Avatar
5150northrider
5150northrider is offline
Default Tire pressure?
A buddy of mine told me to run 45 psi front and 50 in the back on my 2015 cvo street glide what do you guys think?
Top Answer
06-17-2017, 12:21 AM
kngpn's Avatar
kngpn
kngpn is offline
Received 5,116 Likes on 2,674 Posts
I Think you should kick your buddy in the *****.
Old 06-16-2017, 10:51 PM
From_Behind's Avatar
From_Behind
From_Behind is offline
Uhhhh, no?
Old 06-16-2017, 10:56 PM
dickey's Avatar
dickey
dickey is offline
Received 5,473 Likes on 2,475 Posts
Run what your manual says. The PSI on the sidewall is the MAX you can run.
Old 06-16-2017, 11:27 PM
SPRINGER's Avatar
SPRINGER
SPRINGER is offline
Received 3,269 Likes on 1,975 Posts
No on the pressure and if you still have your manual, check that to see what it says.
Old 06-17-2017, 12:03 AM
CVO SG's Avatar
CVO SG
CVO SG is offline
My bike has the tire pressure ratings/specs on the front frame down tube.
Old 06-17-2017, 12:21 AM
kngpn's Avatar
kngpn
kngpn is offline
The following 12 users liked this post by kngpn:
BTLorys (06-19-2017), Capt Steve (06-18-2017), Cozz (06-21-2017), fullautomike (06-17-2017), NCBANDIT (06-17-2017), RandyL (06-17-2017), Stopit (06-17-2017), Super08 (06-21-2017), tar_snake (06-19-2017), tpitman (06-19-2017), Uncle Larry (06-17-2017), will2002 (06-18-2017) and 7 others liked this post. (Show less...)
Old 06-17-2017, 12:30 AM
bigbadpoppa's Avatar
bigbadpoppa
bigbadpoppa is offline
Originally Posted by 5150northrider
A buddy of mine told my to run 45 psi front and 50 in the back on my 2015 cvo street glide what do you guys think?
does your buddy ride? Lol. Hell no!
go with the manual like others have said. If you are an agressive rider, go down a few psi lower.
Old 06-17-2017, 06:47 AM
Rick58's Avatar
Rick58
Rick58 is offline
I'm curious as to where or how your buddy came up with those numbers?
Old 06-17-2017, 07:32 AM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,070 Likes on 2,554 Posts
I actually run less air than what the manual says to get more rubber on the road. And I read it on here in the Soft Tail Section. It makes sense to me.
Old 06-17-2017, 07:42 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is online now
I think you should follow the sticker on the bike that states the air pressure.
Quick Reply: Tire pressure?
