Cooler twin Cam engine
Just as GM went to black paint on engines from Orange and blue - runs cooler. Chrome also makes any engine run hotter.
Hey. I posted a couple of pictures for you. Simple enough. Beauty will be in the eye of the beholder.
tar_snake (07-20-2017)
When I used to drag race we always used black on engine blocks. Got us cooler quicker between rounds. The quicker you get back out there when you're winning rounds the more competitive you remain. Thanks for the backing man.
Because then it does look ugly. The Jim's device looks kind of neat and mounts to the same holes as the timing cover but too pricey for my wallet. Like I said a simple modification that retains a stock/custom look. Thanks.
Oil
I'd be a little more willing to give it a shot if you at least had a temperature gauge to tell us what your oil temperature was before and after so we'd know if it actually worked at all...just saying you feel the oil is cooler coming back to the oil bag is really not to convincing. I realize it's just a couple bucks for some screws but my time is priceless
LenBoyLo (07-20-2017)
Now now. No need for that. It already is factory black.
OK. When I run at highway speeds 231 F was not uncommon with ambient air at 85 to 90 F. Although getting mother nature to repeat exact same conditions is sometimes a challenge, what I have noted since doing this is oil bag temperature on average at 227 F. Small difference but a positive change. I've used an "Oil Bud" cooler since 2011 which is thermostatically controlled to start opening at 200 F. No fan used. The cooler is mostly unnoticeable because it mounts under the engine between the frame rails. Air passes over and under it. Years ago when I was doing a Vegas run and sustaining 80 MPH speeds the oil bag stayed mostly in around 235 F. I use the digital read Harley branded oil dipstick. Has always been reliable when oil is cool and at ambient temperature. i.e. matches outside air temp. Hope that helps. Good luck if you find the time.
I like this, and I'll let you know how it worked on my bike. I may modify it some to make it look cooler, but every little bit of heat dissipation, is a good thing
So harleycharley1992. First off thanks for your support. It cost me nothing but a little time to create and post originally. Never thought there be such serious skeptics though. Seems so reasonable no one out there had envisioned this before. And maybe not even the Motor Company. Anyhow, kindly let me know what you modify to add the cool factor (looks) so I can see for myself. Thanks again eh. Hahaha. Nothing ventured/Nothing gained.
tar_snake (07-24-2017)
Not disputing what you've said, But I know that you have wasted more time on your bike, doing stuff, that does nothing at all. How many wasted projects cleaning under the tank? Or hiding a wire that you think looks out of place? Try it, it sounds reasonable. I am going to. The logic seems to fit reality, and if he's wrong, we can all send him a big bill for our time, that for the first time owning a bike, we wasted!!
