Zuma Garmins on bikes
Hey all, I bought my first Harley from a dealer last month and it has the hook up for the zuma garmin but it didn't come with it. The piece does not have any model numbers on it so my question is can anyone tell me which model will fit on the bracket? Obviously it is a used bike and the dealer didn't know. I have attached a photo of the plug in.
Thanks
Mike
Thanks
Mike
Looking at the picture and the number of pins, it looks like a 590LM or 595LM (LM = lifetime maps). I don't know if Garmin accepts e-mails but you could get confirmation on the zumoforums. If you can get the 4 fasteners off, there should be a part number on the back.
Garmin is closed but I looked at GPSCity and did a search on mounts.
Post back but it looks like it will be a 66X or a 59X.
Received 14,657 Likes
I have had numerous Garmin units and have talked to their customer support many times. They are excellent and could surely give you a definite answer. Looks to me like a zumo 660/665/Roadtech mount that I have had but they could tell you for sure. As above poster stated could even work with the 590 but have not had one of those. Yet...
+1 Looks identical to the mount for my 660. I know it won't work on the later ones because I was looking to upgrade. If you have the mount you may also have the NIM (navigation interface module) that routes the voice through the radio. You will have to pull the fairing to see if you have the nim or look for a plug in the aux in connector on your radio.
ZUMO 660 or 665
Thanks
Mike
Thanks
Mike
donc
02-25-2010 02:17 PM
