2007 FLHT Brake/Running Light and Front Fender Light not working
The front fender marker light and rear tail light/running light stopped working on my 2007 FLHT. The brake light does come on when I depress the hand lever but not when I press the brake pedal. I checked the rear bulb and it looks ok. My front and rear turn signals are working properly. My headlight is working fine as well. Are the lights not working all on the same circuit? Wondering where I should check next.
I also ride 07 FLHT. Last month my rear break light stuck on and my cruise quit working. My problem was rear break switch. Not sure if it could be your issue but easy sequence test to find out. Do a search on this site for "Troubleshooting Cruise Control" and read through first few replies until you find the test procedure. This may not be your problem but can't hurt to check. Hope this helps.
RoadHog659
11-30-2014 04:35 PM
