Are u checking tire pressures?
Received 47,790 Likes
Yep ... Me too.
Pure N2 is used in aviation tires since it's non combustible, and being dry nitrogen it doesn't introduce water into the tire through condensation, during a landing cycle an aircraft tire experiences rapid acceleration and generates a lot of heat, water condensation can flash to steam and the absence of O2 keeps a fire from forming in the interior of the tire when they rapidly heat. O2 also has mild oxidizing effects on rubber, a bike tire should be changed every 5 to six years regardless of mileage and wear so running N2 is a waste of time and money, it provides a false sense of security.
shorelasHD (09-20-2017)
Now if only the MOCO could figure that out....lol
Air also has water vapor in it. When the vapor condenses, you get water in your tire and the air pressure goes down (consider what condense actually means). Nitrogen, if "pure", has no water vapor so you don't get the continuous cycle of building up moisture and losing pressure.
Hot brake rotor? Shouldn't you be checking the pressure while "cold"?
This right here ^^^ The selling point is that N2 is a larger molecule than 02 and thus the tire is subject to less loss due to gas permeability, the reality is that nitrogen is 300 picometers in diameter oxygen is 292 picometers in diameter, a difference of 2.6% in molecule size. N2 expands and contracts with temperature changes just like air. It is more important to keep your tires properly inflated than it is to keep the nitrogen pure.
The larger molecule thing is BS. The difference is the presence of water vapor in air vs nitrogen.
Who leaves a bike tire on for 5 or six years? If you're doing that then it isn't the nitrogen that is a waste of money, it's the bike.
What is the "security" that one looks for in nitrogen?
