Oiling problems
Oiling problems
I ride a 1986 evo and stock upper end s&s cases and oil pump.aftermarket horseshoe oil bag.oil blows out of the vent hole on the bags cap.ive completely removed the pump and the timing cover to check out the oiling system at its entirety.pump scevanger gears and keyways o.k.pump and timing all align.blew out all pasages replaced check valve and spring.looked in my oil bag only to find it empty.added a quart of oil and i blew it out. Check the oil filter then replaced it.what might be the cause.what did i miss.anyone out there have a clue.anything would be appreciated.thanks.john...
If your bike is a head breather, and vented to the air cleaner, I'd say this. It happened to me a few years ago. Umbrella valves were petrified from age/heat. To be fair, I had over 90,000 miles on the motor.
OP, also make sure you aren't using a twin-cam oil filter. It's more restrictive to an Evo.
63796-77A is the right one to use.
Been there done that , blowing out the quart you added, tells me that the oil in the bag had gone to the "dry sump"
always check oil just after engine is turned off.
check valve on my 01 S&S motor failed, added oil, blew it out everywhere
