How's the S&S 110 upgrade kit for 96"
I have a 2011 FXDC. Bought this summer with 12k miles, now has 16k miles.
Runs reasonably good, but more power on the highway for a quick 65mph to 85mph would be nice. I came from a Sportster, before this.
I am considering the (S&S) 110 upgrade kit. Would pay my local custom shop to do the upgrade over the winter.
https://www.sscycle.com/products/110...wrinkle-black/
Have you done this 96" to 110" upgrade on your Dyna and are you happy with the performance, considering the cost?
dailyrider (11-20-2017)
Received 2,189 Likes
i did the S&S 110 and love it. i'm not into headwork and custom stuff, everytime i see somebody say "oh you have to get headwork", i cringe. so i did s&s 89cc heads with cometic .030 mls headgaskets. well worth the money bolt-on. GREAT!!! i later went 58mm on the induction parts.... Ridiculous! i'm extremely pleased. no problems whatsoever. great kit.
Day-to-day is great. it's tame until you rip it. the performance will shame a 110 fxdls no problem....
i did have to upgrade the clutch to a AIM VPC, then i used an SE diaphram spring too... the spring might have been overkill.
cost was about $3500-3700. if you use the links below, you may be able to get the kit and the heads for ~$3000 vs paying 2800 fo the kit alone. then just give it to the shop to install.
results: https://www.hdforums.com/forum/dyno-...0-gaskets.html
- $2000 flat for the 110 power package kit (made these guys and offer, https://www.ebay.com/itm/S-S-Cycle-P...19.m1438.l2649)
- $1000 for the heads ( again... make an offer, https://www.ebay.com/itm/S-S-Cycle-S...item21223099f0)
Work: https://www.hdforums.com/forum/dyna-...l#post16266349
S&S 110 winter power package
Engine
Cam chest
rockers
primary
random
Goodridge 1/4" MCD04V In Line Metal Fuel Hose Quick Release Disconnect Coupling for crossover
Engine
- 4" Bore bolt on cylinder and piston kit
- S&S 89cc heads pn: 106-3240.
- Cometic 4" .030 mls head gasket pn: C9725
Cam chest
- S&S 585 Easy Start Cams in either gear or chain version
- TC3 Oil Pump
- TC3 Cam Plate
- S&S cam chain tensioners or outer cam drive gears depending on selection Quickee Adjustable Pushrods with Tubes
- S&S Premium Tappets
- **Heartland Harley Davidson TC 96 103 110 Dyna Twin Inner Cam Bearing Installer Puller
- **CFU TOOLS Harley Twin Cam 96 Cam Locking Tool
rockers
- box gasket set C9588
- new breathers (17025-03A)
- rockout rocker shaft inserts
primary
- Cometic Gasket Derby Cover Gasket - 5-Hole C9997F1
- beat-up figure machine clear derby cover
- SE clutch diaphragm spring 37951-98
- AIM variable pressure clutch VP95TL
- Cometic Gasket Cometic Primary Gasket AFM C9145F1 0934-1205
- Barnett 307-30-10013 Extra Plate Clutch Kit Kevlar
random
my (already stated) reasons aren't important... carry on
Davdoodles (12-01-2022)
2. If you want a rush between 65-85, use the $4k and buy a used Yamaha VMax.
Your rush will be more significant, your HD will be worth the same and you will have a second bike that will be worth close to what you paid for it for a long time.
Speed is a relative thing. Speed on a Harley imposes a criteria that is the most costly for the least result.
Thanks for the detailed reply. That's pretty much what I'm looking for. Looks like you have no regrets for spending the money to get the performance upgrade. My shop will take care of having the heads done, as the larger pistons and compression won't reach potential if the valves are not addressed.
I'm about to embark on 103 upgrade, but only cause Ive blown up my 96... and the bolt on SE103 kit is actually cheaper than all the stock 96 bits I'd need.
I aint no guru, but if that's all your looking for maybe a better start would be a decent set of Cams. 110 upgrade for some extra highway bump seems a bit over the top.
why "crab in a barrel" it?
Build madness! firebreathing dragon bikes to tell the grand babies about when the world has forgotten what a gas powered motorcycle was...
be Conan... punch camels, kill big snakes, bite vultures, kill wizards... all with your motorcycle!
screw reasonable
Longridertx (11-23-2017)
