Bending metal fuel line. HELP!
Received 47,784 Likes
Killa (02-24-2018)
Filling the tube probably won't work. When the filler (use something water soluble like salt) gets under pressure the rubber section will just expand & the tube will kink like there's nothing in it.
If the fitting on the end has the same ID as the tube, or larger, I've had good results with sliding a tight wound coil spring inside the tube, bending it then removing the spring. The spring needs to be pretty stout, and closely sized to the tube.
Good luck!
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
Good luck!
__________________
NO, they DON'T all do that!
Also on amazon.com...
