Medallion gauge trouble speedometer
Any one have any ideas what would cause my speedometer to act this way?
first off i put a new baker 6 speed in then at the same time I upgraded the dash with all new medallion Bagger gauges , the speedometer in first gear at about 20 is reading 80 or more by the time i hit 2nd Im 140 then it will go back to 0 and start coming back up slowly till about 50 or so then fall again.. I tried to calibrated pre the instructions @ 30 .. it did seam to save it till i tried to run back up to 50 then it went crazy again . I have checked my ground for that was the first thing we thought to check . thanks for any help you may offer |
what bike are you talking about? I had an 03 Road King that did something similar. First try cleaning the VSS. If that doesn't work you may need to replace the sensor or it could be the speedo unit is shot.
Was the new speedo plug and play, or did you have to splice connectors in? Do all the other gauges work properly?
To answer the splice question yes we did have to splice into the harness all other gauges seem to work properly...
the bike is an 01 Ultra Classic that I have done a custom build on.. I also installed a baker 6-speed at the same time I replace the speed sensor because the original one was installed with the transmission without a spacer and it chewed the end of it up I found this through troubleshooting.. I was also told that it needed 60 thousands Clarence . And believe I have achieved that |
Now I'm wondering if I possibly got a faulty speed sensor
Originally Posted by Spec36
(Post 17154575)
Originally Posted by Redoilokie
(Post 17154583)
All that speed sensor does is read notches in the exciter ring. The reason I asked about splices and the other gauges is because it almost sounds like you're getting interference from the tach circuit into the speedo circuit. No wires were pinched, everything is heat shrunk and/or taped, no bare wires anywhere?
I used a good quality heat shrink as well , I deal with that I lot at work testing electronics for power plants |
From what you're saying does that mean if it is reading it all my speed sensor is good?
(Post 17155414)
I will try that I do have a lift with a center Jack that is the way I tested it previously.. it will be tomorrow evening or late tonight before I can try my wife is sick so I'm babysitting for the evening.
I understand to set voltmeter to AC . Without sitting here looking at it I do know there is three wires don't remember the colors right off but the variation of two should give me a voltage if I understood correctly |
© 2024 MH Sub I, LLC dba Internet Brands
