Ride On really does work!
I first used Ride-On when I had the random under 35mph "decel shake" in the front end that I couldn't figure out what was causing it.
I got the recommendation to try Ride-On to see if the problem was possibly a tire balance issue.
I figured for $14 it was cheaper than just replacing the tire.
I added it to the front tire and the shake never came back so apparently my tire had an issue.
When I changed the tire I didn't even think about it, I just went ahead and told the installer not to balance it and then I added Ride-On to it.
I've been using it now for years.
I've never had a puncture so I can't vouch for the sealant function but the balance function certainly works.
I think "hoofnhog's" post vouches for the sealant function clearly enough.
I have two bottles still sitting in the cabinet waiting for the next tire change.
I've found "motorxoutlet" on e-bay as the best place to order it from.
https://www.ebay.com/itm/Ride-On-Mot...ZVzL8q&vxp=mtr
BTW- I just add 1 bottle (8oz) to each tires.
I think for the rear 8oz may be a tad light but it works for me.
BALANCE / SEVERE / TUBE:
You may add
up to 25% more Ride-On tire sealant for
balancing without wheel weights, or in severe
applications.
We recommend adding 25% more product for
tube tire applications
