Can you still plug the tire if needed or leave the plugs at home? Also the website said a small vibration for first five miles when you start out??? Is that annoying??
You can plug a tire (the temporary fix), but you can't patch it (permanent fix).
I have found if you ride the bike immediately after installing the stuff, you don't feel much of anything, and within a few miles, it's smooth going..The only time I noticed anything was when I put it in without being able to ride it and then trailered the bike from Maine to Georgia. When I unloaded it and started out, she thumped pretty good for 3-4 miles..... I think all the product pooled up in the bottom of the tires and they were way out of balance for a bit...... DW
Originally Posted by SWThomas
How do you know the Ride-On sealed the holes when the bolt and nail were still in the tire.
I use it in my tires too.
ummmmmm? it wasn't leaking????
In my experience, most punctures, (before I started using Ride-On), would cause the tire to leak down even with the foreign object still in the tire....
