battery good 20degrees blown circuit breaker???
My bike has been on a Battery Tender, it's outside in a covered shed, it is like 20 degrees here...the battery tender was Green, I went out to just start the bike and let it run...three times to start, the third time it arced under the seat then everything is Dead, Did I fry the circuit breaker???
Received 8,229 Likes
vibrations and battery's not always a friendly combination. How was the tender hooked up? Batt cables are something you need to check out several times a year. The battery tender should be hooked up direct to the terminals....not via the flimsy clips. Keep us posted...let us know what you find.
PaGuy610 (03-18-2018)
You could have blown a fuse or circuit breaker. Depends on what year your bike is.
So, check your fuses and breakers, battery and ground connections. Look under the seat for any signs of arcing or melted insulation.
And like stated above, don't just start your bike to let it run. If you can't take it out on the road to get it fully up to operating temperature just wait for better weather.
