USB charging
USB charging
So I've searched. I've read the topics. I have an issue.
I've tried two different ways to keep a USB cable on my bike for charging my phone on it's mount while I ride. I've had a USB charger with lines that tie directly onto the battery. I tried this first. It worked for a bit. The phone didn't charge quickly, but it charged. Then, the cable just stopped working. Thinking it was a fluke or a cheap cable I bought, I replaced it. The phone started to charge again. Then a few days later, no more charging. I did some testing with other devices around the house and discovered that my charging cord wasn't working. Now that cord I trusted. I had it for years and used it on everything. So I figured ... "Jason, it's gotta be that charger. Perhaps going directly to battery is frying these cables out." As such, I removed the charger from the bike.
I then got a battery USB "tender" which goes into the charging line on the motorcycle. I ran USB cable to it, under my seat and dash, and to my handlebars. Perfect. Phone charged. Now ...after a few days, same issue. Phone not charging. I'm going to bet that this cable is no longer working either. So, any ideas why I keep frying cables out? Anyone have a SUCCESSFUL phone charger installed on their bike?
Thanks in advance,
-TJ
Thanks in advance,
-TJ
Received 14,135 Likes
I phone 7+ so I'm going to assume the wide 30 pin connector. And I really don't want to have another accessory to charge when I can just plug into my bike like in my Jeep.
The 7 uses Lightning cable. I use a battery tender USB converter and an Apple cord. No issues over seasons of riding.
I have a lot of aftermarket cords, not cheap ones from the gas station, but nice heavy duty ones that I've had for a long time. They always work until plugging into the bike. Has it anything to do with it being a CAN BUS system?
Maybe the heat from the motor is damaging them. I'll try running a different route and come back after a few days.
I bought this from Amazon for my Road King, it is mounted to the handlebars and I have it connected to a switched power source for my 8+, it works great.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
If a USB charger is powered directly from the battery then charger is converting power from battery voltage to 5 volts 24 hours a day...even with bike OFF.
Although it is a small amount of power, the unit is working and creating a draw on the battery.
If the unit is not designed for constant 24 hour use then it is possible the unit might be overheating and the exposure to engine heat might be pushing the unit over the edge.
It would be best to have a USB device that provides the amperage required by your phone and that USB device be connected to a power supply that functions ONLY when bike is ON.
