Bike started running rough and check engine light
Hey folks,
Hope y'all can point me in the right direction. I rode my 2015 Iron 883 yesterday for a couple of hours and right as I got home left the bike running while I opened the garage door it started running rough and missing..and then it shut off. It has never done that in the six months I have owned it. It only has about 4500 miles on it. It started right up and I pulled it in the garage and went on. Thought it was a fluke. Well went to ride this morning and got about 15 minutes away and it started missing and running rough and the check engine light came on. So headed home and ran the diagnostics and it showed
ECM – Yes
SPDO – Yes
ABS – NO
BCM - NO
came up with the following codes:
U0156 - Lost Communication With Speedometer
P0263 - Rear Injector Open/Low
U0001 - CAN bus Fault
U0121 - Lost Communication With ABS
So after reading some posts on the forum about old codes still showing I cleared the codes and started the bike and let it run a few minutes and reran diagnostics. It then showed
ECM
SPDO – NO
ABS – NO
BCM – NO
The ECM was blank and when I went into it I only saw NO RSP
So not sure where to go with it at this point any advice is appreciated.
ECM – Yes
SPDO – Yes
ABS – NO
BCM - NO
ECM
SPDO – NO
ABS – NO
BCM – NO
tomcatg (07-02-2018)
Well I got home today and after reading other posts on the forum I remembered the bike got soaked in a heavy summer rain last week sitting in the driveway. Someone had a similar problem after washing their bike and used contact cleaner and dielectric grease on the ecm pins and fixed the issue. So I thought it was worth a try and did the same. Took about a 10 mile ride right here near the house and ran great, no missing and no check engine lights etc. Checked codes after I got home and everything was clean, no codes. I am not 100% convinced that its fixed as that seems far too easy lol. We will see I guess...
