Engine stall
Old Sep 26, 2018 | 02:59 PM
Parrothead 1977's Avatar
Parrothead 1977
6th Gear
Default Engine stall
I recently bought a 2006 Street Glide, bike is in great condition,runs well. But on a few occasions now when I’m at slow speed coming to a stop, the engine just cuts off. It starts back up again after I switch the ignition off and on again and hit the start button. I’m planning on taking it in to get it checked, but was wondering if anyone else has experienced this problem. I know a lot of you have been riding a long time, so curious to see if this has happened to you and what may be causing this.
Old Sep 26, 2018 | 03:06 PM
mmesa005's Avatar
mmesa005
First step is check for DTC codes. How to here: https://www.fuelmotousa.com/p-29661-...ble-codes.html
Then a common culprit is a dirty IAC valve that can easily be cleaned. Read here: https://www.hdforums.com/forum/touri...our-iac-3.html
Old Sep 26, 2018 | 03:11 PM
wolfpak's Avatar
wolfpak
IAC valve...clean or replace...I had a 2007 Electraglide classic with the same issue. I cleaned it first but still it acted up. I then replaced it and never had anymore issues.
JoeRu
Oct 14, 2018 06:24 PM
dynamac
Nov 27, 2010 10:13 PM
bstein1994
Sep 8, 2010 10:59 AM
rking2000
Jan 30, 2008 11:59 AM
LadyStreetGlide
Jul 27, 2006 03:17 PM
