1st time winterizing my Harley
So I'm sure Ill get laughed at but its worth it to get some solid information. I live in Michigan and it gets cold so how much should I actually do to prep this Fat Boy for storage? What I've gathered so far is I should add some fuel treatment, drain the oil and remove the battery and store it inside. Is there anything else anyone suggest ? Should I store it up on my floor jack ? Any help would be appreciated
If you're more than half way through your engine oil interval, change the engine oil. Fill the tank COMPLETELY full (with ethanol free fuel if you can get it) and add Sta-Bil. Run the engine for a few minutes to cycle the stabilizer into the injectors. Clean it and cover with something breathable (no tarps, just asking for mold). If you have a lift, get the tires off the ground. If not, jsut move it about a foot ever couple weeks. Attach a battery tender and start counting down to spring.
Don't get too **** about it. First: get a good battery tender and hook it up. Next: run the engine until it's hot. That will clear out any moisture. Then run it with the fuel off to clear fuel out the carb. Add stabil to the tank if you don't have a full tank of gas. Then: put it up on your lift. Finally cover it with a light breathable cloth dust cover. That's it. Cold has absolutely no affect on a bike. Nor does cold do any harm to a battery. However, moisture can occur if after a cold spell you get a warm damp spell. Personally, since 1975 I've just used a battery tender and my lift. That's all. Never had any problems with fuel, oil, or battery or anything else related to winter. And I put on lots of miles.
What I use to keep the rodents out. Cheap dryer sheets. I've been using them on my boats, bikes, anything in'winter storage'. Done that for years, never an issue. Any scent type works great. Just stuff them easily into any crevices, cubby holes etc. Come spring they go into the wife's laundry room. 3 per bike. About 9/10 in my fishin' boat.
Received 4,353 Likes
