Nitrogen in Tires
  #61
Old 10-13-2018, 04:05 PM
CndUltra95's Avatar
CndUltra95
CndUltra95 is offline
Originally Posted by Guitarman_sg
Must be, the question is when you switch to nitrogen, will your stock cables still work...
I was thinking how it might affect my speedometer myself ...
It was popular on M/C 10 or 12 years back, but eventually fell by the wayside.
Guys with to much money in their pockets will add nitrogen just for bragging at the cafe'.
Rob
  #62
Old 10-13-2018, 04:08 PM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,557 Likes on 5,153 Posts
It has advantages in theory . But in a motorcycle not worth the effort. or the cost.
  #63
Old 10-14-2018, 07:43 AM
Cosmic Razorback's Avatar
Cosmic Razorback
Cosmic Razorback is offline
Received 16,716 Likes on 6,881 Posts
My local ford dealer put it in no charge on my Mustang when I purchased new tires. And they had a great price on the tires!
It does work as advertised.
  #64
Old 10-14-2018, 07:20 PM
Grim's Avatar
Grim
Grim is offline
I do some pretty long trips on my Limited ( 7-9 Thousand miles ) and have been changing tires due to cupping. With the TPMS I have noticed the rear tire will go up to as high as 55 lbs. ( 40 cold ) I blame this on the cupping. When I got back from last trip I decided to try Nitrogen. Just by letting the air out and refilling with Nitrogen the highest the pressure got was 48. Decided to try a vacuum pump, it just popped the tire of the bead. Removed tire and cleaned wheel and tire with alcohol then installed dry. Took a lot of pressure to bead. then hooked a vacuum pump up to it for 5 minutes. Rode it for an hour and tire pressure stayed at 40. I will know more next season when I'm two up and loaded with gear. Unfortunately riding season here is over. I also have a AC Vacuum pump and a Nitrogen tank at work so cost was minimal.
  #65
Old 10-15-2018, 04:12 PM
rleedeuce's Avatar
rleedeuce
rleedeuce is offline
I could understand HELIUM?, but nitrogen something sounds fishy.
I used to pump my Harley tires up with helium and it made that darn bike light as a feather.
Then I all ways took home the trophy for best e.t.
Yessuh. That was back in the day. Why we had a wild cariboo as a pet, I tell you.
Lived in a shack up the road, under the freeway.
Yessuh! That's right!
  #66
Old 10-15-2018, 05:52 PM
houstonhdguy's Avatar
houstonhdguy
houstonhdguy is offline
I switched to unicorn farts instead of nitrogen...
  #67
Old 10-15-2018, 05:57 PM
st john's Avatar
st john
st john is offline
Really $60.00, they do it here for $5.00 per tire if you want it. Here is Phoenix. Look around but do not pay 60.
  #68
Old 10-16-2018, 07:27 AM
Super Glidester's Avatar
Super Glidester
Super Glidester is online now
Received 17,561 Likes on 9,792 Posts
Originally Posted by Bestrafen
The biggest scam in the automotive market. Keep your money in your wallet.
So true, but if people are willing to pay for it so they can brag at the local watering hole, someone is willing to sell it. I bet some garages are just filling tires with air and installing green caps. How would ya know?
  #69
Old 10-16-2018, 08:04 PM
OLD 96's Avatar
OLD 96
OLD 96 is offline
Received 2,230 Likes on 901 Posts
Not worth the trouble. That is all I have to say about that.
  #70
Old 10-16-2018, 10:48 PM
Prot's Avatar
Prot
Prot is offline
Received 14,115 Likes on 6,203 Posts
Just thought I would add that in the Jeep world, CO2 is popular, but for different reasons.
Quick Reply: Nitrogen in Tires
