Nitrogen in Tires
#31
#32
Received 17,574 Likes
No ****, I was working in a garage years ago. I had a guys Dodge pickup on the lift doing a State Inspection. The owner was talking alot of **** like fellas do to a garage mechanic. At one point he says" yeah the tires have Nitrogen in 'em. Its what they use in NASCAR" I looked at him serious like the ******** I was back then and said "yeah?, this isn't a NASCAR race car..."
#33
Everyday consumer use of nitrogen is a scam. I know most race teams use it because of its lesser expansion with heat. Car rolls out with 80 degree tires (ambiant) at let's say 25 pounds of pressure. After a warm up/pace lap, tires are at 150 degrees and 30 psi and at this point are not 100% safe to kick the snot out of but won't roll off the rim. After 1 semi-into it lap they are at 250 degrees and 38-40 psi and can take some real abuse. (These are ball park #s based on experience, but im not selling trade info here. Auto cross guys should just set full pressure and run it, your not out long enough to build notable heat) same scenario but with air and the pressure swing is far far greater and would almost require you to head out with 15 psi and that's a sure fire way to break a bead loose before the fun starts. Situations like this we typically will never seen on our bikes. I've felt my tires after a lengthy highway run and they don't get very warm, 120 degrees maybe. So the pressure fluctuation is negligible. And as far as leaking..... If you have a leak its gonna leak period. I have seen many nitrogen inflated tires loose air.
I can almost assume that the aviation use of nitrogen is done for a similar reason to the race use of it. It makes sense. But again, these aren't situations your bike will likely ever see under normal use. When's the last time your bike saw a 20-30,000 foot elevation change in a day much less its lifetime. My .02.
The following 2 users liked this post by ScottinAZ:
J_MOSH (10-12-2018),
shorelasHD (10-11-2018)
#34
#35
Nitrogen-two advantages. nothing to do with bike tires
1, - You can get 2000 lbs pressure from it-
So its great for accumulators and such.
2, - There is no moisture it to rot tires, so aircraft use it.
3, you can buy a tank at the weld shop for nothing last time I looked.
So the 60 dollars for HD is another RIP-OFF and might as well call it an "SE stage kit "
I am sure they have the nitrogen molecules chrome plated..
Congrats to HD for another customer rape of the wallet job.
You pissed at them yet?
#36
#37
#39
If you feel you have to use N2 just buy a bottle .it will fill a LOT of tires
There is 2000 lbs in them
I would guess 20 to 100 tires depending on what size you bought.
But 60 bucks a whack at the HD shop is a RIP OFF!
https://www.ebay.com/bhp/nitrogen-cylinder
