Notices
Flat Tire question
Old 11-06-2018, 10:22 AM
213_LooseNoodle's Avatar
213_LooseNoodle
213_LooseNoodle is offline
One Of The Regulars
Liked 6 Times in 3 Posts
Default Flat Tire question
Hello I have a rear flat tire on my 97 FXDWG.
Tire was flat when I got up this morning (I use the bike to commute everyday).
Can any bike shop fix it or should I go to a harley shop?
Thanks
rm
Old 11-06-2018, 10:24 AM
213_LooseNoodle
One Of The Regulars
Also, is it safe to fill it with air and limp to the closest shop?
Old 11-06-2018, 10:29 AM
Pantera99's Avatar
Pantera99
Pantera99 is online now
One Of The Regulars
Liked 24 Times in 21 Posts
Fill with air, find the leak. Can purchase tire plug kit cheap at harbor freight or any auto parts store. Or If it's not a huge leak u can ride it to a shop nearby.
Old 11-06-2018, 10:30 AM
Architect's Avatar
Architect
Architect is offline
Liked 479 Times in 352 Posts
Any good independent shop or the dealership should be able to fix you up.
Put air in it and see if it holds some air. Give it 15 or 20 minutes to see what it does before riding. It may not hold air long enough to get you anywhere. Good luck.
Old 11-06-2018, 10:53 AM
nobodyknowsme's Avatar
nobodyknowsme
nobodyknowsme is offline
Liked 1,544 Times in 1,188 Posts
I am assuming that you have a tube in that tire? You will at least need a new one of those, possibly a tire. Any kind of bike shop should slick you up.
Old 11-06-2018, 11:07 AM
Oko's Avatar
Oko
Oko is online now
Liked 247 Times in 178 Posts
You've lost your original HD air. Your bike warranty will be voided if you install any 3-rd party air.
Old 11-06-2018, 11:12 AM
Kingglide549
Kingglide549 is offline
Liked 926 Times in 672 Posts
Helping the helpless that have their brains in a wheelchair.......
You should IMMEDIATELY get rid of this bike being this stimied you!
What ya gonna do when you get low on
gas?
oil?
Cbyway's Avatar
Cbyway
Cbyway is offline
Liked 747 Times in 457 Posts
I would do as someone else stated. Air it up and find the leak. It may just be a loose valve stem unless you can see the object in the tire.
I carry a plug kit and CO2 cartridges for emergency use. A plug is only designed as a temporary fix although I have put years of wear on plugged tires on ranch vehicles as well as older truck tires I was planning on replacing soon anyway. I would never trust a plug in a motorcycle tire for anything more than a direct trip to have the tire properly fixed or replaced.
I know there are those who will say run it if it's not leaking. I even ride with a guy who has two plugs in his rear tire.
Old 11-06-2018, 11:13 AM
Sanjuro's Avatar
Sanjuro
Sanjuro is offline
Senior Rider
Liked 109 Times in 80 Posts
Personally, I would not risk patching a motorcycle tire, or trying to "limp" to a repair shop.
If this were a car, no worries - I have 3 other tires.
For a motorcycle, if you loose one tire, it is potentially tragic.
R,
Sanjuro
Old 11-06-2018, 11:20 AM
chuckw2's Avatar
chuckw2
chuckw2 is offline
Liked 91 Times in 80 Posts
Wide Glide with spoke rims has a tube. Can't plug that. Probably won't hold air long enough to get anywhere. Unless of course you've changed to a tubeless spoke wheel assembly. been there done that.
Featured Sponsors
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
