Chaps for cold weather riding?
druski (11-11-2018)
I wear chaps with snap in liners when temps are between 30* and 50*. They work very well. Once the temps are below 30*, I wear insulated leather overalls. I have worn them as low as 12* and they're marvelous. I don't use heated gear. I layer under my jacket above the waist. With the chaps, once the temps drop below 30*, I've found the uncovered crotch area begins to suffer from the cold wind passing over to the point of burning. I can ride with my chaps for hours comfortably as long as my upper body is layered well.
This are my overalls: http://www.stonelakeleatherworks.com/bibs.htm
druski (11-11-2018)
I've lived in New England and I've live along the Wasatch Front and I've never owned or worn a pair of chaps. I guess some folks like them but I've never seen the need especially now that I live in Florida. I figure since I've never seen a snow ply down here then it never really gets that cold. The do look good on long legged women though. But on men, not so much.
I abandoned my chaps 10 years ago when I discovered flannel lined jeans. I live in the Atlanta area and ride year round - it's never been too cold for anything other than the flannel lined for a typical commute. Now, if I'm headed out on a 400 mile lunch ride in 35-40 degree weather I'll throw the overpants on as well.
druski (11-11-2018)
Thanks
You could try freeze out gear. I used it when I was riding in the Bay Area in CA as rolling up in the mountains would drop the temp sometimes 40 degrees. You can wear under jeans pretty comfy all day unless it’s real hot in the work place.
The freeze out gear was on clearance with cycle gear earlier this year for like 80% off.
I had horse hide chaps for years on my metric cruiser. Work well. Unless it rains. Then you have to pull over and squeeze rain pants over them. If you do buy chaps, don't bother with the thin lamb-skin, fashionista kind. Get horse hide or at the least cow-hide. If you have crash bars, put the leather wind covers on them also.
Now I wear insulated Carhart jeans. I put long johns under them last week in mid to upper 40's. My plan is to get textile pants this winter or use my snowmobile pants.
If you want chaps, I have these heavy horsehide with industrial zippers. They fit my fat **** up to my 44" waist. They can be adjusted down. 32" inseam and they run a bit long to cover boots. PM me if interested.
