Motivation and cost to switch from FI to carbs?
Top Answer
12-31-2018, 08:19 AM
What a load of EFI holier-than-thou bullshit. Beware the mis-information in some of the above posts.
CV (constant velocity) carbs are fine at elevation. Once dialed in, they are dead reliable and virtually maintenance free.
I've been up to 14000 feet numerous times without issue, and have gone 100000 miles with minimal maintenance.
EFI requires dyno to dial in, not something that can be done at home, and is reliant on the electrical system to function. Carbed fuel delivery stands alone.
Your preference for one or the other depends on your expectations.
The following 2 users liked this post by Jackie Paper:
2wheelwanderer (12-31-2018),
ShadowforNow (12-30-2018)
Death Valley Ultra (01-01-2019)
Received 5,373 Likes
It can and has been done many times before. Search the forums here, and you will find those that went from a pain in the *** EFI setup to a pain in the *** carb setup.
My take on it is this...... EFI can be a pain in the *** to get running right if its malfunctioning. when its running right, its pretty maintenance free. Carbs are a pain in the ***, and require more in the way of periodic maintenance and cleaining. I was happy when I came to Harleys and left my Goldwing 1000 with its FOUR carbs behind. I know Harleys use a single carb, and have fewer issues than a multi-carb setup, but there are still issues with carbs that I will never miss. Plus if I NEVER have to sync multiple carbs again, it will be too soon.....
mrmarklin (01-01-2019)
The following 15 users liked this post by RHPAW:
AJSHOVEL (01-01-2019),
fsae0607 (01-03-2019),
Greezey Rider (12-31-2018),
joes bar and grill (01-01-2019),
Kingglide549 (12-31-2018),
and 10 others liked this post.
