The Best Method To Tie Down Your Motorcycle?
#41
[QUOTE=Mallard Slayer;17951005]a good quality wheel chock is a must!! and then fasten it well and you will have no problem securing it with just two straps I usually just attach to lower fork legs as not to compress the suspension
I agree with this, EXCEPT:
i never strap the front end.
Attach a strap to the frame on each side of the bike under the seat area. Attach them to floor mounted shackles about a foot forward. When tightened down, the front forks will slightly compress and be secured in the chock and the rear will also be secured. The bike won’t budge.
#42
#44
Received 5,374 Likes
#45
Received 14,656 Likes
https://www.bwtrailerhitches.com/product/biker-bar
#46
I always put a block of wood under the frame. You can cinch down the front end without putting undo stress on the front suspension. I takes out any bounce while traveling. Same principle as the biker bar. For my springers, I slam the shotgun shocks onto a 4x6 block. For bikes without shotgun shocks, I do exactly what 2Goldens described in post #37 … build up a block to fit. Using wood blocks makes cheap wheel chocks okay … I use Tow Rexx from etrailer.com. Two straps up front and two in the back to keep it from dancing side to side. Kickstand always up. I do not ever strap to handlebars. For bikes with an alarm system, don't forget to put it in trailer mode. Don't ask me how I know. Carry a battery charger incase you forget.
#47
You can (and probably will) get as many opinions on here as to how to tie a bike down as there are articles and videos on the internet. I use a chock for the front wheel and soft straps around the forks above the fender, attached to ratchet straps pulling slightly forward. Also a strap across the back to keep the rear from jumping around if the road is bumpy. That's about as succinct as I can make it. Always has worked on my bikes.
, And with no engine guard either.....
Best way.....get the help of a second person.
Wheel chock is a good idea yet not always available, so make sure to bring front
tire all the way to the front of the wall of the cargo hold.
Strapping to handle bars instead of over the lower triple clamps is my votes.
Proper tie downs and extension straps to go over the handle bars are vital.
Compress the forks 3/4 of their travel, almost to its full travel.
IMO only need to tie down the front.
But, I have never traveled with this setup cross-country so there may be
better advice, except for my first sentence above which I think is # 1 best way.
I bought a pair of "tank straps" and a harbor freight wheel chock, similar to a condor, and use this guy's method to tie it down. Towed my 2018 electraglide ultra classic 1200 miles round trip like this on my utility trailer and the bike never moved. It felt solid with the trailer, but the suspension was able to absorb any bumps in the road.
I did add one strap to each rear floorboard just to keep the rear end from moving.
https://www.harborfreight.com/1800-l...ock-61670.html
https://www.amazon.com/Tank-Straps-M.../dp/B0798SSQJD
https://www.youtube.com/watch?v=Vh5zO1__oNc
I don't know...but I could watch this instructional video all day...
https://www.youtube.com/watch?v=nqMYl8fAf-A
#48
