Noise from my clutch.
Old 01-12-2019, 05:42 AM
Gidon's Avatar
Gidon
Gidon is offline
Stage II
Default Noise from my clutch.
Hi,
I am new to this forum and have a question regarding my new Harley.
I just purchased a 2017 (but new) V Rod nightrod.
While downshifting at low speed from for example 3rd to 2nd gear, with half clutch, the clutch is clicking and I can feel it in the handle as well as hear it.
It's intermittent . The dealer indicated that it's normal.
Is anyone familiar with this problem (or not a problem) and if so, what was done to remedy it?
Thanks,
Gidon.
Old 01-12-2019, 12:27 PM
K Melancon's Avatar
K Melancon
K Melancon is offline
When I had bike with cable clutch. While cruising at low speed if I let off throttle fast I could hear the clutch lever slap the housing as the cable tightened up. I could not hear it at speed but could feel it if I took the slack up with the lever. Normal.
Old 01-12-2019, 01:08 PM
Gidon's Avatar
Gidon
Gidon is offline
Stage II
Thanks for the reply. I believe the clutch on my bike is hydraulic, not sure if there is a cable.
Regards,
Gidon.
Old 01-12-2019, 02:36 PM
dickey's Avatar
dickey
dickey is offline
Received 5,473 Likes on 2,475 Posts
Regards,
Gidon.
How can you not KNOW this?
Old 01-12-2019, 04:38 PM
Coverdog's Avatar
Coverdog
Coverdog is offline
Sounds like maybe his first bike?
Old 01-12-2019, 04:53 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,516 Likes on 3,773 Posts
Even if it's hydraulic, it has a flat needle throw out bearing. It would need to be really torn up to hear it. They are very small. (Think lazy Suzanna)
Maybe that. When that go bad, clutch setting is iffy. If yours is hydraulic, may not have a setting. Trust your dealer or get a service manual. I would do the later. However, I am surprised he did not come up with a 3 figure repair.
Old 01-12-2019, 07:25 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 4,281 Likes on 2,349 Posts
If you are the first owner of a left over new 2017 model from a dealer I'm almost sure the bike is under warranty, why not take it to the dealer and have a tech ride it and downshift like you do, then down shift with a full clutch. Have you posted in the V-Rod sub-forums?
Old 01-12-2019, 07:37 PM
Jackie Paper
What exactly do you mean by half clutch? I assume you mean you fill it in handle bars.
Be sure you are pulling clutch all the way in and hit the shifter with a firm stab to the bottom. I have re-read your post. It being a new bike would not have a worn throw out bearing.
Harley transmissions gears are all engaged. What engages each range is a sliding ring with 6 huge keys that pop into gear and lock it to the shaft. If you do not stab it, the clicking is thoes keys hitting and not dropping in. Don't do that. Hit it. Outboards on boats are similar.
If you been doing that long, I would have the change transmission fluid at first service.
EvMason
05-01-2019 08:22 PM
Dynadev
11-15-2016 10:21 AM
Toner123
02-28-2016 12:30 AM
EZRider76
04-29-2015 07:55 PM
marine_hm@hotmail.com
07-18-2012 08:50 PM
Quick Reply: Noise from my clutch.
