Did Harley fix the M* oil in the air cleaner problem
Make sure your ol is not overfilled. Every f-n to:RC my dealer changes oil, they overfill it. When your oil is at operating temperature it should register 1/2 between full & add. If it’s at the full mark, you have a much higher chance of bow out.
BTW...your rationale for the big box and full filter...are highly speculative, and I think your are wrong. JMO..
Not all of the Harley air cleaner designs are enclosed on the bottom and the ones that are have plenty of room around the element to breath. I haven't had a problem ever with this oiling, I keep the oil level at less than full and it's so far worked for me.
Twin cam had venting problems too but outside of these few forum pages, to the vast majority of Harley riders, this "problem" does not exist.
Correct. And by keeping the oil at the level I mentioned I have no blow out. And no gathering in the bottom of the air box. My 103 Twin Cam is much more sensitive. I have an open AC..and if I get a bit too much oil in the motor it blows out all over my exhaustbandcwife.
You may not realize it, but the Dealer probably is not over-filling your oil. They are probably putting in the recommended amount of oil. If you google this problem you will find that people have to put in less oil than recommended in order to stop the blow-by.
I have been googling like mad trying to discover any known problems for the M8 engine. Most of the problems that I found I am not to concerned about , but there is one problem that I think might be real and I am wondering if they have address it?
Apparently, there is a problem with the breather oil accumulating in the air cleaner on long rides and eventually, leaking out and dripping onto the bike and blown back on to the bags (for a bagger).
Here is a picture of the stock air box on a M8 Touring bike. Look at it? It looks to me like it is designed to capture a significant amount of oil. This makes me think that the oil blow by problem might be real. When you put on a high flow air cleaner, that "air box" is removed from the bike.
Is this a problem for 2018 M8 engines? Also, recall, that the M8 engines are oil cooled. The have a 5.5 quart capacity if I remember. All of this is making me think that this could be a real problem.
As far as I can remember, this is the first Stock Harley Air Filter that I can recall that is designed this way, by which I mean, to hold a liquid on the bottom. Every other filter I can recall seeing may have been shrouded, but it was always open at the bottom, it was not designed like a cup.
Like others, I can't believe it was designed to hold liquid. Think about it. If it was designed to hold liquid, wouldn't it eventually get full? Does the service manual tell you to check it and empty it or clean it if you find liquid in it? Very likely the shape and the enclosed bottom have more to do with keeping the intake quiet.
danhahn (01-24-2019)
Well, don't you find it odd that an air filter would not be exposed on all sides? A major factor in my suspicion is that I do not think that any stock filters for the Twin Cam were designed that way. I only see this kind of stock filter on the Touring bikes.
Also, I only see it on the 107 M8. I do not see it on the stock 114 bikes.
