Bike won't roll in gear with clutch pulled in
2012 Softail Duluxe wont budge with engine off, in gear, and clutch pulled in. This wasn't always the case and it shifts fine when running.
I assume it could be the clutch needing adjustment so I watched a couple videos on the procedure but would appreciate any comments from this knowledgeable group before removing the derby cover.
Any insight is greatly appreciated.
They all do that, especially when the clutch has cooled down. The plates stick together, nature of the beast. They get broken apart when you put it in gear. That's why you start in neutral with the clutch have in, so you don't beat up the starter.
The times it didn't do it the clutch plates were warm. If you don't have shifting trouble, I wouldn't say the trouble you're having is indicitive of needing a clutch adjustment.
NCBANDIT (01-27-2019)
Received 14,139 Likes
