When your ABS fails
Received 14,657 Likes
When your ABS fails
Yeah, good time for sure. Out for a great ride today, nothing but sunny skies and upper fifties. I was rolling down a rural road when I see blue lights flashing down the road. Out of habit and curiosity I edge the bike towards the center line wanting to have a clue if I was going to have to make a U turn but the van in front of me, nobody in front of him was way over the double solid yellow lines. All of a sudden the van decides it is time to jump on the brakes and I was admittedly too close. I grabbed a bit of the front lever but jammed the rear and the frigging thing locked up. NOT what one expects with ABS.
This is only the second time since owning this bike that I have had to push the envelope up but the first time it didn't do what it was supposed to do. I will be taking it to a dealership ASAP.
I guess I am posting for the most part to warn and check your own ABS. When you instinctively count on something and it doesn't work properly when you are counting on it, this causes HUGE pucker factor.
You should practice threshold braking every 6 months. Engage the ABS in a vacant parking lot so you know it's working and what it feels like when you stand on the brakes.
Touche, pays to know the variables before TSHTF moment.
If the system fails, isn't there a warning light?
I’ve had the same thing happen with my rear but it didn’t stay locked, the abs did kick in. I’m assuming you were on the Road Glide? I wonder if it has something to do with the amount of weight transfer and basically “unloading” the rear when braking hard.
Just me and my arrow rolling at about 40 MPH. Hell no I barely had time to realize that my rear tire locked up before having to take evasive action. Pucker factor prevails!!!
Received 14,144 Likes
Received 5,383 Likes
Now, to the OP~
When I first opened up your thread, I thought it was going to be a "Got zero brakes due to ABS module failure."
Glad it isn't that. Also glad to hear you didn't make contact with the vehicle in front of you. Also that when your ABS brakes malfunctioned they allowed you to skid. Skidding is better than nothing! (Skidding may allow shorter stops than ABS, but don't tell anyone that.) ABS may have let you run into the vehicle in front of you, if it were working as designed....
