Ruff idle and dies
Ruff idle and dies
I am having a issue with my 2009 street glide running Ruff and dying at idle.
What I recently found was that I had a bad spark plug wire and have since replaced them and plugs.
Hopefully not, but I am thinking that the front cylinder is damaged. Thing is she runs fine through the gears and at riding speeds.
Baffled at the moment.
.I had a similar problem with my 2008 I did some trick with the ignition switch(key) not handle bar switch on /off in a sequence within a timeframe. resetting the ecu I found the info someplace on this forum.sorry I couldn't give more info but it worked for me.mine was like the bike was in limp mode on idle .
Received 4,308 Likes
A few things come to mind.
1) Variable Speed Sensor is dirty or defective
2) Fuel filter is dirty
3) Pinhole in the fuel line (inside the gas tank)
I had an 03 Road King acting like you described. I cleaned the Variable Speed Sensor, which didn't work, so I replaced it. Still had the problem so I pulled the tank off and removed the fuel filter and fuel lines inside the tank. Sure enough a tiny pinhole in the fuel line was causing low fuel pressure and would let the bike die at stop signs or idle.
