I had a pair on the two rear shocks on a Polaris ATV. Worked fairly well at keeping the gritty, sandy muck off the shock rod so it wouldn't eat up the seals. IMO, I can't see what purpose they would really serve on a street bike though.
I’m sure the “purpose they serve” is to make money for the company that makes them.
Designed for Dirt Riders and works much better than not having them so I am told. You must rebuild your shocks a lot. Street, they hold in the heat which is no where good. Oil is very thin when hot. I believe that just keeping your shafts clean as well as your threads. I rebuild many HD street shocks and at the (my) recommended 37K mi interval, and the owner keeps his shocks clean, the oil is black from heat but there is no real amount of external road debris in the shock. The same shock from a guy who never cleans his shocks, expect $18K mi or less before parts are worn out.
Just say “no” to those things in a street application. As H.G. Messner says, keep your shocks clean and you’ll be rewarded with longer shock life/rebuild intervals
