88 twin cam
02-10-2019, 03:09 PM
88 twin cam
Curious thinkin bout puttin a cam in big red any suggestions much appreiated its a 04 softail standard with 88 twin cam motor got a se heavy breather
Big red
Reason: Pic
02-10-2019, 03:34 PM
02-10-2019, 06:26 PM
SE204... If you decide to go to 95” later you can take it with you.
02-10-2019, 06:30 PM
88 twin cam
Yeah i dont plan on goin to 95 ci but thnk you for the input
02-10-2019, 07:04 PM
I have S&S 509 in my 2000 Heritage. I don’t have a tach but the power is perfect for the 5 speed gear spacing IMO. The sound is aLeo wonderful
02-10-2019, 07:17 PM
Location: kingman AZ. We aren't in hell, but you can see it from here!!!
I had S&S 510s in my '00, pretty good low end power and nice top end speed. An,d didn't effect my MPG too badly,
02-10-2019, 07:21 PM
Watch Doc Harley on YouTube on his 3 part video on cams for more info.
02-11-2019, 12:24 AM
Andrews 21s work good in 88s.
02-11-2019, 04:41 AM
I put S&S 509G in my 02 Fat Boy. They are a good cam if the engine is basically stock otherwise. Gave it a noticeable gain in torque and a little bit of lope at idle. For sure have the flywheel run out checked and determine if you can go with gear driven cams while you are doing it. I see a lot of people say the cam chain adjusters lasted crazy long miles in their bikes, but I did my cams at 20,000 miles and the adjuster shoes in mine were in pretty bad shape. I was happy to get rid of them.
02-11-2019, 09:18 AM
'04 tensioners are probably mechanical... Go hydraulic.
