Remove Scratches on Windscreen
The harley factory shields have a coating.
An abrasive will alter/destroy the coating.
When the coating is destroyed it will cause the area destroyed to become visible with polarized sunglasses.
Leave it alone or replace.
Although some cleaners can make it a little less visible if it is left alone.
Received 1,224 Likes
For minor scratches and abrasions, I've used Maguiar's PlastX (clear plastic cleaner and polish) with good results using a low speed buffer as well as by hand. Any scratches beyond minor, you should probably replace the shield, especially if they impair your view.
Someone mentioned toothpaste, and to that I would say no, don't do it! I did that once and learned my lesson the hard way many years ago. It may look fine in the shade, but in the sun you will have no visibility whatsoever through the area you used the toothpaste on.
OkieBill (02-15-2019)
eventually the scratch was gone, along with the outer coating in the area I buffed. It looked absolutely terrible, visible
from a mile away.
I ended up getting a new windshield.
kk
