Bleed brakes
Peace.
Buy one of these and follow the brake bleeding instructions in your Harley Davidson Service Manual.
https://www.harborfreight.com/mityva...ump-39522.html
The following 2 users liked this post by RK4ME:
Bama Lee (02-12-2019),
username already exists (02-13-2019)
Or to make life much easier you could invest in a set of these;
https://www.demon-tweeks.com/uk/stah...-valve-245978/
It's easier with 2 people but first is it an ABS type motorcycle ? If not to bleed the front pump the brake lever a few times , have the brake nipple on the caliper just home and as you hold down the lever break the nipple free just a little, till it takes the lever in a bit then tighten the nipple off,fill reservoir, repeat a few times till it's tight at the lever. Similar for rear.
Peace.
Peace.
Make sure to practices safe sex, when you breed those brakes.
You have a big air bubble trapped somewhere. I would bleed the master cylinder on the bench, then attach the hose, and bleed down the line, to get most the air out, then attach the line to the caliper and bleed until all traces or air are gone. Sometimes you have to apply pressure to the master and leave it applied overnight, if you have a really stubborn bubble in there.
Received 4,317 Likes
If rear then the brake bleeding tool is your friend.
If front just tape the leaver back and leave it over night with the wheel turned to the left, sometimes it helps to either tap the brake line in many places or start the bike and let it idle for a few minutes.
As for breeding brakes turn on some **** and leave out a tube of ky and they should handle the rest themselves...
