Remap? If just change air intake?
Received 4,281 Likes
Hey Man (03-07-2019)
I'm a bit ignorant on some of this, but wouldn't that depend on what filter you remove?
Just changing the filter, even if it's less "restrictive" won't introduce more air into the engine unless the filter that was there in the first place was restricting it- right?
I've heard, for example, that the stock air filter on my 2014 Limited isn't restrictive (based on what I've read on other posts on this forum), so if in my situation, if my filter isn't restricting air intake, putting on a less restrictive filter wouldn't change anything.
But like i said, I'm not anywhere near an expert here................
I am thinking, now, that the reason the stock backplate is restrictive is because of the stock exhaust. If I un-restrict the backplate, will the engine suck in more air or will the exhaust ultimately determine how much air the engine can suck in? I think what will happen is, the engine WILL suck in more air, but the back pressure in the exhaust will increase. Either way, I think I just convinced myself ,with the help of the comments, (thank you) that I should remap.
I assume when you said changing to high flow intake you are doing more than a filter change. Remap is necessary.
Best $300-400 you can spend.
Next step change the exhaust. Even Slip ons will make a big difference. Stock comes with EPA Compliant mufflers that are very restrictive. Most riders replace with non- compliant mufflers to get more sound and more air flow. More air flow in. More air flow out.
I put Screaming Eagle Slip Ons on my 103 ci dyna. Which are EPA compliant. Mainly because I live in Commiefornia. Even they made a big difference in power. Others can tell you about Vance & Hince EPA slip ons. V&H and Fuel Moto have a map to match.
