making my landscaping trailer a towing trailer
goinig to tow 2 bikes on a typical 7 by 12 trailer. so Ive got the chocks. one up to the front, the other a foot back - so our handlebars dont hit each other. Now I have to mount the mount points for the ratchet straps. this trailer came with notihing good to attach to. my question is of angles. If I use the handlebar things - canyon dancers - can the straps go pretty much straight down and out a foot, or do they really need to go towards the front of the trailer? my front chock being so close to the front does not allow for much of this. should I move the chock back a bit? or is barely going fwd enough to be secure?
or ditch the canyon dancers totally and just attach my soft straps and ratchet down from the forktube? I pic from the top would be great, youtube has a lot of different videos, Id just like to do it the right way, since im able to design my own system.
thanks!
dave
thanks!
dave
yeah, the mounts are going to be on the floor of the trailer. my question is mainly of angles. should they be in front of the front tire, or straight out? since my chock is waaaay up at the rail, the mounts will be even with the chock. I might want to move my chock back a bit so I get maybe a 45 degree angle from bike to trailer? and is the further the cables go OUT from the bike better? I dont have much space. maybe a foot or foot and half from bike to mount.
thx
dave
thx
dave
Received 8,229 Likes
I would try to mount a bit forward and outward of the chock.. The idea is to pull the front end into the chock and to have the tie downs angle outwards a bit to provide some side to side stability. I would also try to put something on the back end of the bikes to pull back a bit (once the front end is tied down). Again rearwards and slightly outwards of your desired mounting points on bike.
The whole intent is to provide a secure mount to prevent front and rear movement and side movements. I don't believe you have to be forward or outwards a great deal... a few inches should be enough. I would try to take a look see at other trailers... perhaps find an adventure rider or dirt bike source of info and ask what they do. You near any dirt bike shops? they may be able to give you some advice.
For only two bikes that are not going to be directly behind each other, it's hard to beat two condor type devices through-bolted to the trailer as a starting point.
