FP3 not linking
Received 4,307 Likes
I just checked my app tutorial on the Android phone. First question is, "Is your Bluetooth on?" Are running your phone on a WIFI signal? I would try a cell signal to do the download. Suggestion pull your headlight fuse, you'll thank me later, if you have a battery tender plug that in also.
Make sure your harley battery is fully charged. Keep it connected to tender.
I had similar priblem when battery ran down before FP3 could complete its processing. It takes a while.
Has your Sportster been previously tuned to other device. If so your ECM only recognizes that device.
Make sure both Run and Ignition switches are ON
Check this thread for same problem
https://www.hdforums.com/forum/ignit...-download.html
Thanks
Or if it makes a difference. If probably doesn’t. But worth inquiring.
