Wheel bearing change
For me, the cost of the bearings pales by comparison to the dangers associated with failure.
Whether doing the work myself or paying someone else - I am a big fan of the "while you're in there" line of thinking.
All that having been said, when I get tires, I get wheel bearings, maybe every other time.
While this may seem like overkill, the cost, in the overall spectrum of what this passion of ours costs, is fairly nominal.
guido4198 (04-17-2019)
I check them every tire change. I had a sealed one get 'notchy' just under 10k. If anything doesn't feel perfect they get swapped out.
The old tapered roller bearing system is infinately better, arguably more hassle, messier, but smarter.
I got all the tools, tires, bearings, everything, so I can blame the proper retard when my wheels fall off. I don't trust anyone......mostly.
Received 8,243 Likes
I lost a front wheel bearing on a trip... on a highway in Virginia traveling about 70mph and it went. Fortunately the exit I got to was only 2 miles from a Harley dealer. They replaced the front wheel bearings and got us off and on our way. They went the extra mile, treated us well, and I did not feel ripped off....they sympathized with us being on a trip and did us well. I got home and ordered a wheel bearing removal/install tool and a set of All Balz bearings for the rear. I think I will need a tire this spring and plan to replace the rear bearings at that time. My plan is every other tire will be bearing change time. Call it what you will, but until you experience it yourself, ain't nothing like it!!! I'll spend the money to ensure my safety!
As a matter of fact, I changed the rear bearings/hubs on my 2011 Town & Country van last fall. Had one of the rear going out!!!
If you are worried, raise the bike up and spin the wheels. Or take the wheels off and eyeball. For the $40-50 cost of bearings (well there is the install price as well...) you probably **** away more than that every now and agin!!!!
I am following along the same line of thinking that sooner is better than wait for a problem. I have noticed a small amount of noise from the back. It could be the tire (just received a new rear tire from JP Cycles) or maybe
a bearing.
Where did you get your bearing removal / install kit? How much did it cost?
Thanks,
SUP
a bearing.
Thanks,
SUP
All you have to do is jack the wheel off the floor. Holding the wheel top and bottom give it a good strong push and pull. Any slight movement means the bearings are worn. You can obviously do the check when you want as many times as you like. No need to wait for a tyre change and no need to remove the wheel.
I have changed the bearings in the front wheel. If a dealer wants anything over $80 to do the job with cost of bearings on top then that will pay for a proper bearing removal and install tool. I would suggest you do it yourself as it is very easy with the proper tool.
