Notices
Alternator cover leak
Old 04-29-2019, 12:54 PM
Kaki
Kaki is offline
New Member
Default Alternator cover leak
Hi everyone. Recently i changed a metal gasket from an alternator cover on my V Rod VRSCA 2002, and now it has a small permanent oil leak at the bottom bolt number 11 location.
Any suggestion please? Any idea how to fix this?
Thanks
Old 04-29-2019, 01:16 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 2,485 Likes on 1,435 Posts
Do it again. Don't f**k it up this time.
The following 4 users liked this post by RHPAW:
chopperdog45 (05-01-2019), Dirty Harry (05-01-2019), fxdup (04-29-2019), tar_snake (05-16-2019)
Old 04-30-2019, 01:44 PM
Kaki
Kaki is offline
New Member
Thank you very much for your reply. I did not understand your message mate. What do you mean by saying " Don't f****t it again? What did it i do wrong? and what eshould i do again please? Your comments greatly appreciated.
Old 04-30-2019, 02:49 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
First make sure it isn't coming from the stator plug wire...that's a known issue.
Next make sure the mating surfaces are clean and flat...no nicks or debris.
Use a thin coat of Permatex (gasket sealer) on all surfaces.
Last, make sure you tighten all cover screws gradually and evenly...don't tighten each one all the way before moving to the next one.
Check for the proper torque requirement, and don't exceed it on any particular one.
If it still leaks after that, you may have a warped cover and will need a new one.
Kaki (05-01-2019)
Old 05-01-2019, 12:16 PM
Kaki
Kaki is offline
New Member
Thank you ever so much for a detailed explanation. My vision is now clear
This Sunday I will redo it and will let you know of the outcome.
Cheers!
Old 05-01-2019, 01:31 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Tighten the screws gradually in a kind of star pattern, for a better chance of sealing it evenly.
Old 05-01-2019, 01:56 PM
seniorsuperglideE8
seniorsuperglideE8 is offline
Received 1,070 Likes on 745 Posts
So, you're the one that bought the V-rod. +1 with ensure the surfaces are clean ,clean, clean. Use some oil resistant RTV to fill in any gaps on the engine case and tighten the fasteners in a star pattern gradually till tight then use the minimum torque specs for final tightening.
Old 05-01-2019, 02:42 PM
Labrador's Avatar
Labrador
Labrador is offline
+1 on redoing it. Maybe there was debris on the surface, maybe the gasket material has a deformity or lack of material in the area.
Old 05-16-2019, 03:33 PM
Kaki
Kaki is offline
New Member
Thank you everyone. I redone it, no leak now....💪👍
Cheers
Old 05-16-2019, 03:43 PM
RHPAW's Avatar
RHPAW
RHPAW is offline
Good job! You gained skills.
Wheelerza (05-16-2019)
Featured Sponsors
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
