Cometic Rocker Gaskets
Has anyone had trouble with the Cometic Rocker gaskets leaking? I rebuilt the upper end of my Twin Cam 103 last fall. Was very careful cleaning and torquing everything. Now after 600 miles I notice the rear rocker gaskets are leaking at the rear cylinder. After taking it apart there is nothing evident that would cause a leak. I am replacing them with the Genuine Harley gaskets with the sealant applied to the gasket surface. Just curious if anyone else has had trouble withe these gaskets. Thanks in advance, Dave.
I have often heard it said by pro builders that if they were to use HD gaskets in only one place it would be the rockers. I do the same & even reuse them.... never a leak. I think they run about $6 each... cheap insurance.
For ROCKOUT information & purchasing please click HERE For all Twin Cams and Evo Big Twins & Sportsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Lakerat (04-30-2019)
1 2 many (04-30-2019)
