So how long do spark plug wires last
I had one go bad after 50,000 miles they where Accel glass race wire won't use them on a hog again. Not just the heat but the vibration is hard on them. Friends bike had one that was bad can't remember the miles but under 100,000 by 20- 30,000. I have mororso 8mm wires from summit racing on it now and a stock set barely used as spares on the wall. Like was mentioned checking ohms is a good idea after the miles add up or just replace.
cprhed (05-16-2019)
I don't know the wear rate. What I don't like is when people say they are working so why change, or still good. Things wear over long period, and you don't notice. Look at tires and brakes. If you ever do do a lot of miles in short period, it will shock you.
Does it really matter about the plugs, I dunno.
Iron lHorse (05-13-2019)
Bama Lee (05-16-2019)
