Why you should do your own work.
Received 4,614 Likes
If you're competent at all with tools, you'll do things on your own bike shops don't. They don't clean the surface rust that's almost always under a spoke wheel rub strip - I found a 3/4" crack in the butt weld covered over by rust that easily brushed off. How much life was left in that rim... I always pop plastic seals off sealed bearings (won't use any with metal shields) to make sure they actually are greased adequately and with something that looks like grease, not vaseline (many have that clear stuff now). I always grease or anti-seize all metal contact points for axles, spacers and pivot bolts, some shops will do that, but not all. I do my own tire and tube changes, amazing how out of balance some shop installed tires are, and a bunch of weights all crammed end to end usually do not equal balance, just "close" and with that much weight will vibrate even a little off. I've pulled a few onces off and rebalanced with less than an once and got it right on. Torque - I believe in torque wrenches and have seen shop mechanics just do it tight, and you strip out the philips or allen trying to get them loose. Lots of reasons to do it yourself if you can, can't be too perfect when you only have two wheels on the ground.
The following 2 users liked this post by Imold:
Cheesehead_13 (05-12-2019),
Sorce (05-15-2019)
Pride in work
Getting paid a flat rate is not an excuse to not take pride in your own work. If you dont care to do a good job in what ever you do, get out of the way , let someone who does and find something else to do. If a “professional” can’t do something better than I can...then they “aint” no professional!
IMO, possessing a mechanical ability is something a person born with, you can't teach it. So some have it, some don't. Alot of people know HOW to do something, and as long as everything goes smoothly they can complete the task, but at the first sign of trouble they become lost because they don't know WHY they're doing what they're doing. Actually having a mechanical ability, or just following steps are two different things.
I have always prided myself on being self sufficient on most things... except drywall, I SUCK at finishing drywall...
The following 3 users liked this post by 0maha:
Years ago when my wife was pregnant, I put in a double window in the family room to brighten up the room for her. No problem shoring up the ceiling, removing the siding, cutting and framing in the opening and installing the window. Then came the drywall... not terrible, but not all that great either. At that time my wife said something to me that has stuck with me, "obtain a REASONABLE level of perfection". She was perfectly happy with it so I had to learn to be too. I get it honestly, my father was a perfectionist extraordinaire...
Your dealer is blowing smoke up your ***,they can Warranty all non wear items under your two year warranty. I would call HD and file a claim and get a claim filed. Lesson one is never have a dealer you used to work for do your service,it looks bad if you have a issue and need to attorney up. lesson two is if you worked on it and F---ed it up your wrench is fixing it or my attorney will be calling you. Also report them to the BBB they hate when that happens.
