Looking for some help
Old May 14, 2019 | 01:12 PM
"HI"'s Avatar
"HI"
Because the Rear Fender Extension Splash Guard got chewed up by the rear tire.
Does anyone know if I need to remove the tire to replace it?
Old May 14, 2019 | 01:19 PM
RHPAW's Avatar
RHPAW
I just meant that in my mind, that section should be enclosed fender, and not some "splash guard". Is the Moco getting so cheap they can't put a full fender on anymore?
To answer your question,,,Yes, I would imagine a proper and secure installation would require removing the tire, if nothing else, to be able to access the fasteners efficiently.
I'd put a real fender on it, though..
Old May 14, 2019 | 04:19 PM
"HI"'s Avatar
"HI"
Is the info for the security alarm in the ECM?
Old May 15, 2019 | 10:45 AM
"HI"'s Avatar
"HI"
Plugged in the ECM directly into the harness and the bike fired up, so Im assuming the ECM is still good. The bike still doesn't recognize the key fob as I had to manually put the code in. Is there a security module on the bike somewhere?
Old May 15, 2019 | 01:06 PM
"HI"'s Avatar
"HI"
Power Vision I or a Power commander V?
Old May 25, 2019 | 03:36 PM
"HI"'s Avatar
"HI"
So I ended up buying a used PCIII on ebay for about $125, got it, now need some help on picking the right map, Im considering these 3:
Bike Info: I bought the bike used and the previous owner did all of the work:
S&S Big bore kit (I have no idea about the cams)
Freedom Performance Sharp Radial Curve Pipes (2:2)
After market air cleaner (Brand????)
Stock ECM
2007 Harley Davidson Softail *Advanced Map*
Bassani Pro Streets 2:2 exhaust
Screamin' Eagle 103" flat top pistons
Screamin' Eagle 255 Cams
Screamin' Eagle air filter
Stock ECM
Vance & Hines Big Radius 2:2 Exhaust
Stock ECM
Rev Xtend enabled
Fuel table 1 is rear cylinder
Khromewerks 2:2 exhaust
Stock ECM
Rev Xtend enabled
Whats the difference between these?
Old May 25, 2019 | 07:59 PM
Bone Doc's Avatar
Bone Doc
No, the TSSM (Turn Signal Security Module) handles the security.
Old May 25, 2019 | 08:10 PM
b bop n bob's Avatar
b bop n bob
You can contact dynojet and they can probably explain the difference. However, not knowing the type of cam makes picking a map difficult. .
Old May 28, 2019 | 10:53 AM
"HI"'s Avatar
"HI"
I did contact them, they are recommending this map:
Bassani Pro Streets 2:2 full exhaust (without baffles)
Stock ECM
Rev Xtend enabled
Blackp5ca
Sep 23, 2024 12:27 PM
SGT. Rosie
Nov 3, 2020 12:38 PM
"HI"
May 20, 2019 02:43 PM
busij44
EVO
18
Jul 18, 2012 08:28 AM
PsycleFreak
Jun 21, 2012 06:05 AM
