For a cheap easy fix simply put a star washer between the riser and the bars. https://www.amazon.com/Stainless-Ext...49860572&psc=1
When you tighten the bars down the points on the washer dig into the riser and the bars and they won't move.
If you want to change the angle later simply loosen the clamp move the bars do desired position and re-tighten.
can you give me more ideas about this? How many washers? only one? What about the metal mesh for cleaning the dishes? I cant find the star washers in Europe....are they like standard washers or not?
I bought today bycycle tube, so I will try wrap that around the bar and put the clamp over.....I was searching for double side sanding paper could not find it.....
Skateboard "grip tape" keeps my Breakouts 16" apes from moving. Its got a very strong adhesive backing and stays in place... I picked up small piece from a local skate shop.
can you send me a piece via mail? I cant find this stuff in europe, I can paypal you
