Battery
I am sure that we will all be using Lithium Ion batteries in the near future, but for now I believe that the cost outweighs the benefit. A 50Ah LiFePO4 battery runs about $400, and will weigh in at about 16 lbs. That is four times the price of an EastPenn ETX30L AGM battery, which weighs 23 lbs., only 7 lbs more. That's weight difference is inconsequential on a touring bike. Granted a LiFePO4 battery will start the bike faster, and may even last longer, but I doubt it will last 4x as long. You will probably also need a new charger/ maintainer for the LiFePO4 battery.
In the future I would make the switch, when technology is up even better, and cost comes down even more.
Not sure I see a benefit myself for a Li battery- Weight savings mean nothing to me on a #900 bike. I got 5 years out of the HD AGM battery that came with the bike, I would hope to get at least that out of the AGM I replaced it with.
Interesting to me that you're supposed to use a special charger for Li batteries, but don't have to modify the bike's charging circuitry.
Shorai
World Superbike and Motoamerica racers use Speedcell - USA made and 3 year warranty. Comes in racing connector configuration
for external charging that's easily adapted. Comes in three sizes - 2.5AH, 5.0AH and 7.5AH - with largest for touring bikes and weighs
2.5lbs. Here - https://www.motomillion.com/products...t=592866934798
Factory Ducati, KTM and Kawasaki Superbikes use Skyrich - Chinese - as their OEM battery. They are available in numerous sizes
and like most are smaller than a conventional AGM battery.. Number 20 size / Softails - https://shopping.shadetreepowersport...ce-hjtx20ch-fp
Same battery rebranded -
The charger you'll need - yes, they are different so don't be fooled -
Whatever you do don't buy an old tech lithium battery that's prone to overheating and exploding like a WPS - get the LiFePo - lithium, iron, phosphate
design.
https://www.amazon.com/Tecmate-Optimate-Lithium-TM-471-Charger-Tester-maintainer/dp/B00Y38X7WI/ref=sr_1_10?crid=IAK6CZXK904R&keywords=lithium+battery+charger+motorcycle&qid=1559841597&s=automotive&sprefix=lithium+battery+charger%2Cautomotive%2C195&sr=1-10
design.
Received 4,307 Likes
RK4ME (06-06-2019)
+1 on Deka. This is where I get mine. you can find a code for an even cheaper price.
https://www.techbatterysolutions.com...RefineBy_2835=
I hope this helps.
I hope this helps.
Lithium battery charger .......
is because when LiFePo batteries voltage gets below 11.4 volts a stepped charging sequence must be used to keep from damaging
it. When lithium batteries are charged to a voltage above that level they are very tolerant of charging voltage swings.
