Harley Davidson Forums
Harley Davidson Forums (https://www.hdforums.com/forum/)
-   General Harley Davidson Chat (https://www.hdforums.com/forum/general-harley-davidson-chat-29/)
-   -   No power to fuel pump ,no spark (https://www.hdforums.com/forum/general-harley-davidson-chat/1287623-no-power-to-fuel-pump-no-spark.html)
Hounddog07 06-10-2019 04:47 AM
I have a 2002 dresser I got on it and it ran good for about 2 miles and the guages went crazy and it just quit fuel pump want come on and it want fire . I replaced the crank shaft sensor no luck ,replaced the fuel pump relay no luck , checked all the fuses they are all good , I can take the cover off the fuel pump relay and manually make the pump come on but still no spark . Any help would be greatly appreciated
Dieselss 06-10-2019 08:30 AM
Ck all the fuses?
What's the battery like and volts?
Hounddog07 06-10-2019 08:37 AM
All the fuses are good that I can find on the whole bike and it has a brand new battery
RHPAW 06-10-2019 09:09 AM
Are there any other relays on the frame near the battery?
Hounddog07 06-10-2019 09:10 AM
Yes 2 they seem to work .
RHPAW 06-10-2019 09:16 AM
Make sure of that...I had one go bad this Spring that shut down everything on the dash and the turn signals.
Hounddog07 06-10-2019 10:32 AM
The turn signals work and when you arm the system with the handle bar switch thr tack will move just a touch .
RHPAW 06-10-2019 10:37 AM
Try switching the plugs to the relays to see if it makes any difference.
joes bar and grill 06-10-2019 12:18 PM
Makes carburetors and points look good.
Hounddog07 06-10-2019 01:20 PM
It is fuel injected
© 2024 MH Sub I, LLC dba Internet Brands
