Rocker box gasket
Rocker box gasket
I have a 88cc with 20k. The rear cylinder gasket between the rocker box and head is leaking so very little.not much at all but enough to notice it left rear corner. Is this something "major" since it is only from inside the rocker box cavity. Engine compression is 145 150 on both cylinders. Can it wait until riding season is over?
If you don't have a repair manual I recommend that you find one. Pay attention to how the old gaskets orient when you take them out. Oil passages must line up. Put Masking tape on the push rods and number them 1.2.3.4 from front to back or back to front. They are all different lengths so don't get them out of order. Torque the fasteners, should be good to go !!!
Received 5,384 Likes
Fairly common on the EVO's but I've never had an issue with the 88's or 96's.
My cousin's 2000 EVO Springer developed a bad leak on the front cover during a trip 2 years ago and it was getting messy.
A dealership in NC replaced the covers for him and I'm not sure but I think the tab was in the $300 range.
An indy would no doubt give you a better price.
Do the push rods have to come out when replacing the rocker gaskets on a twin cam? I changed mine on one of my evos and didn't need to remove them. Matter of fact, it was so easy to do it was scary. I changed them about 8 months ago and I still check to see if they're leaking because it was too easy!
