Oil Leak......Imagine That!
Good day all:
As can be seen, I have a minor leak at the lifter cover. I've looked at the shop manual and read the forum suggestions and have a few questions (It looks like I'm not the first to encounter this inconvenience):
* If I pop the clip and raise the push rod cover will that expose the problematic O ring - I don't have to dissemble anything else (see next question below)? I'm going to try turning the cover and re-seating the O ring first before doing anything.
* Several on the forum have use the old, "cut the O ring and gorilla glue it back together technique" with good reported success.
* I just wiped the leak (there's very little oil), am I at risk of loosing oil pressure and doing any serious damage if I run like this for a few days?
* What would cause this on only one of the four push rods?
Thanks all. This is why I love this forum. This is something I think I can fix myself (presuming it's not a bad lifter or something like that). Any suggestions, warnings or advice would be greatly appreciated.
Jay
Jay
Hit it with some brake cleaner to clean the area and then LEAVE IT THE F ALONE.
If you get dirt in there or cut the O-ring you're in for a ride or tow to the shop, That little bit of oil is not worth worrying about, it's not going to hurt the bike.
Just clean it and keep an eye on it, if it just seeps like that it's not a problem.
rjo3491 (06-25-2019)
Received 19,618 Likes
The following 2 users liked this post by TwiZted Biker:
Campy Roadie (06-27-2019),
Mattbastard (06-26-2019)
