Running a bike with out pipes for a test and need so help
Old 06-26-2019, 09:22 PM
Iron lHorse's Avatar
Iron lHorse
Iron lHorse is offline
Received 2,341 Likes on 1,151 Posts
Default Running a bike with out pipes for a test and need some help
So I removed my old pipes to put on a new set , and just to see what it looks like at night I started the bike . And what I’m seeing is the rear cylinder puts out a very faint amount of blue flames but yet the front cylinder puts out about 3 inches of flames .
So shouldn’t they be the same ?
Old 06-26-2019, 10:00 PM
ChopperBill's Avatar
ChopperBill
ChopperBill is offline
Received 3,963 Likes on 1,203 Posts
That’s a no, no!
Old 06-26-2019, 10:02 PM
monkeyboy22's Avatar
monkeyboy22
monkeyboy22 is offline
*sniff* *sniff* What is that? Oh, burnt valves.
The following 4 users liked this post by monkeyboy22:
AJSHOVEL (06-27-2019), blue flht (06-28-2019), Lucky Dog Willy (06-27-2019), TwiZted Biker (06-26-2019)
Old 06-26-2019, 10:09 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,481 Likes on 1,540 Posts
What did you think you were going see ? There's fire going on in there ! If you only started it for a second you will be OK, but i wouldn't do it again.
Wouldn't it be interesting to see what it would look like holding the throttle wide open ?
Old 06-26-2019, 11:04 PM
0maha's Avatar
0maha
0maha is online now
Received 4,667 Likes on 1,660 Posts
What do you mean "test"? Test what? What were you hoping to learn?
Old 06-26-2019, 11:56 PM
Buster217's Avatar
Buster217
Buster217 is offline
Not questioning what you're saying but I'm curious what is going on in this situation that would burn the valves?
Old 06-27-2019, 12:50 AM
OlAndrew's Avatar
OlAndrew
OlAndrew is offline
Dunno about burning valves, but I've seen valves warped under those circumstances.
Engine runs, valve gets just under red hot. Then shut off, cold air rushes in the port, and warps the valve or bends the stem.
IronAss (06-28-2019)
Old 06-27-2019, 06:56 AM
monkeyboy22
Burned was probably the wrong term. As OlAndrew said, it's an old hot rodder's description of warped.
Old 06-27-2019, 07:17 AM
Iron lHorse
I didn’t go for a ride any where I just ran it at idle for a min or two .
Old 06-27-2019, 07:34 AM
Super Glidester's Avatar
Super Glidester
Super Glidester is offline
Received 17,557 Likes on 9,789 Posts
..I see what ya did there.....
Quick Reply: Running a bike with out pipes for a test and need so help
