We installed new 20" bars. Wiring looks good, new battery, new fuses and new quick valve. Now we have no power. Not sure where to start troubleshooting.
You might have pinched a wire and grounded it to the frame. That happened to me this past week putting
new Dominator mini-apes on my FXDL. Found the pinch, fixed why it pinched, fixed the pinch, re-assembled,
all is well.
In my experience, pinched wires would allow bike to start and then blow a fuse. I would pull tank and look at electrical connectors that you had to add extended wires for the longer bars. I bet you put a wire in the wrong numbered pin. Take a look and see if your wire color codes match up on both sides of connector. Are turn signals, horn, lights working?
