Neutral problem on 2016 Street Bob?
Greetings all... new to the forum, but I can't find this issue anywhere on the internet. I have no issues physically shifting into neutral, but my neutral light won't initiate maybe 50% of the time. When this is the case, I can't start my bike. Odder, to get it to register neutral, I actually have to bounce on the seat. The light will flicker on and off... eventually it will stay on, and the starter with then turn work.
Anyone? Thanks in advance!
2016 FXDB, Stage 1 (Vance and Hines Short Shots, Arlen Ness Big Sucker, SESTP)
I know I’m in neutral:
1. Bike rolls easily without clutch lever pulled
2. If I sit down aggressively (bounce), the N light will come on and/or flash on and off. I have to do this a few to several times at various pressures before the N light stays on and the bike then allow me to try to start.
Last night I did trace the neutral wires back to the transmission and pulled them off the cap. One had a slight bit of corrosion (white powder) inside. I wiped clean with alcohol swap. Now N light seems to be much more normal.
Slight NEW twist: when shifting into neutral and sitting on bike, N light comes on. If I stand, N light turns off. This happens with bike started and running as well. Is there a weight sensor for safety?
kavenius (07-12-2019)
Pull your neutral safety switch and make sure its clean push the plunger in a few times and make sure it clean inside. It is the switch on top of the transmission that you traced the wires to. Don't worry there are no surprises when pulling it. It is a simple plunger switch. It sounds more like a wire issue but easy enough to clean the switch and eliminate it as the problem.
Ok, all replies are correct. And not..........
So I figured more out tonight.
Issue 1: Neutral light still not engaging for unknown reason
Issue 2: Safety switch (plunger) not be pressed far enough
There’s the magical temp fix, #2. Concurrently, the bike just won’t f’in start. If I push the plunger with my finger, even with N light not lit, bike starts. So I glued a little something onto the plunger for now and all good. I’ll figure the electric issue out with the N light with patience. At least I can start the damn bike now!
Thanks all for you replies and offerings...
